Plasma 42PFP5532D/12 bloqué en digital TV
MessagePosté le: Mar 29 Nov - 09:24 (2011)    Sujet du message: Plasma 42PFP5532D/12 bloqué en digital TV Répondre en citant
la seul solution pour effacé ce mode c'est d'utiliser le logiciel compair avec son boitier
une 2eme solution qui a ete rapporter a plusieur reprise et donné par CC il me semble ( et je n'ai jamais essayer )
c'est de remplacé l'eeprom
aucun reset n'est possible car pas d'access au menu
Jonathan
voici l'info technique philips en anglais bien entendu
Symptom
TV-set is blocked in digital mode with blue screen (only the volume action from the remote seems to react).
Cure
INFO:
The TV set did not get out from the "factory mode" in a good way. To correct this, it is needed to go in and out "Factory mode" again.
CURE:
Make use of the ComPair tool, and download/upgrade the "ComPair Chassis Fault Finding" file to version 1.05 (or later). This version is available from the Philips Service Network Support website.
After installation, launch the ComPair application and select the "LC7.2E xx" chassis:
1) Select option "Service Solutions".
2) Select option "Service Solution in case of Factory Mode".
3) Place the ComPair Interface in front of the IR reciever of the TV-set.
4) Select "Click here to switch 'off' factory mode".
5) Wait for 5 seconds for ComPair to complete the task.
6) After this action, make sure the first Option Byte is set to 19_DEC. If the option is set to 23_DEC, activate SAM mode, and change it to 19_DEC. This last action is to make sure the set is correctly out from virgin mode.
REMARKS:
Note that after you have executed above described "refresh" method, the set may have lost its display code, resulting in "sometimes no picture" or "sometimes wrong picture format" symptoms. The correct display code then needs to be re-entered (see Service Manual, but also GSC_64237 "Unable to set the correct display code" might help in this).
IRIS CODE:
1711 (defect code 14, repair code C2).
HISTORY:
04-JAN-'08: Added REMARKS.
MessagePosté le: Mar 29 Nov - 09:24 (2011)    Sujet du message: Publicité
cylou
MessagePosté le: Mar 29 Nov - 09:49 (2011)    Sujet du message: Plasma 42PFP5532D/12 bloqué en digital TV Répondre en citant
Aih ! En effet sans compair je suis cuit Sad
Je n est accès aux menus en effet, galère
Obligé de le faire fonctionner en mode dégradé..
Changer l eprom c est le bazar, me reste a trouver une âme charitable pour m aider Embarassed
MessagePosté le: Mar 29 Nov - 09:55 (2011)    Sujet du message: Plasma 42PFP5532D/12 bloqué en digital TV Répondre en citant
ou de contacté tout simplement une station technique philips sur lequel je pense tu t'en tira pour pas trop cher .....
Jonathan
MessagePosté le: Mar 29 Nov - 09:58 (2011)    Sujet du message: Plasma 42PFP5532D/12 bloqué en digital TV Répondre en citant
Bonjour a tous,
cylou a écrit:
Aih ! En effet sans compair je suis cuit Sad Changer l eprom c est le bazar
En effet, remplacer l'Eeprom c'est assez complexe.....
cylou
MessagePosté le: Mar 29 Nov - 10:08 (2011)    Sujet du message: Plasma 42PFP5532D/12 bloqué en digital TV Répondre en citant
Et en switchant sur la carte je devrais pouvoir accéder au SDM ?
jakovasor
MessagePosté le: Mer 30 Nov - 21:26 (2011)    Sujet du message: Plasma 42PFP5532D/12 bloqué en digital TV Répondre en citant
Quelle galère, en plus le boitier compair est hyper cher http://cgi.ebay.fr/NEW-Philips-Compair-Interface-Box-with-Cable-with-Power-…http://cgi.ebay.fr/NEW-Philips-Compair-Interface-Box-with-Cable-with-Power-…
cylou
MessagePosté le: Mer 30 Nov - 21:41 (2011)    Sujet du message: Plasma 42PFP5532D/12 bloqué en digital TV Répondre en citant
C est en effet le prix qui est bloquant sinon dans l idée pouvoir
mettre a jour le logiciel ne m aurait pas déplu.
Je suis dans une impasse, j ai du mal a comprendre pourquoi il n existe pas un hard
reset matériel
Une petite idée du prix pour le faire débloquer par un pro ?
MessagePosté le: Mer 30 Nov - 22:03 (2011)    Sujet du message: Plasma 42PFP5532D/12 bloqué en digital TV Répondre en citant
cela depend de la station technique mais je pense qu'entre 20 et 70€  sa doit le faire
en plus le compair que tu montre est perimé ... LOL il y a un nouveau COMPAIR 2 boitier plus petit
en plus il faut le logiciel + les manual service integres au logiciel
donc en acheté un c'est pas gagné
bon sinon une foi passer dans une station technique il vont modifier les options du tv pour que cela ne se reproduise plus .... et de plus il y a de grande chance qu'il te mette a jour le soft
jamal
MessagePosté le: Ven 2 Déc - 21:06 (2011)    Sujet du message: Plasma 42PFP5532D/12 bloqué en digital TV Répondre en citant
bonjour. j' avais  le meme probleme .bloqué en dtv .en sdm err 12 . changemant de  l eeprom 7h03 est une solution faite
cylou
MessagePosté le: Sam 3 Déc - 12:25 (2011)    Sujet du message: Plasma 42PFP5532D/12 bloqué en digital TV Répondre en citant
Je precise que je peux utiliser les sources auxiliaires, je peux donc utiliser la TV
avec les réglages usine et les modes 'persos' que j avais mémorisé
Pour remplacer l eprom, il faut en programmer une vierge j imagine..
Techniquement je saurai faire mais j aimerai essayer de switcher la carte
pour voir si j ai accès au menu SDM
Je ne sais pas si toutes les marques nécessitent un
retour SAV pour un 'simple' reset mais la prochaine
ne sera pas une Philips !!
cylou
MessagePosté le: Mer 28 Déc - 16:42 (2011)    Sujet du message: Plasma 42PFP5532D/12 bloqué en digital TV Répondre en citant
Salut a tous
Problème toujours entier, je cherche donc une station technique pas cher en région parisienne ou une âme charitable
pour me remettre ça d' aplomb
Galère quand même de fourrer la TV dans la voiture pour ce genre de panne Evil or Very Mad
yonel
MessagePosté le: Lun 23 Jan - 21:06 (2012)    Sujet du message: Plasma 42PFP5532D/12 bloqué en digital TV Répondre en citant
Bonjour.
J'ai un écran LCD Phillips chassis LC7.2ELB.
L'écran est tout bleu, impossible de choisir une entrée je suis moi aussi bloqué sur Digital TV.
Je n'arrive pas à entrer en mode SDM avec le code télécommande 062596 + OSD ("i+"), par contre j'y arrive en démontant le téléviseur et en court-circuitant le switch SDM.
Donc en SDM j'ai le code erreur 12:
12537 LC72EL2-1.08
ERR 12 0 0 0 0
OP 023 006 010 223 008 002 005
Mais là encore avec la télécommande je n'arrive à rien, je ne peux aller plus loin dans le SDM.
Mon idée serait de réinitialiser la télévision en restauration d'usine mais à priori ce n'est pas possible sans CompAir.
Quelqu'un peut-il m'aider?
Par avance merci.
MessagePosté le: Lun 23 Jan - 21:12 (2012)    Sujet du message: Plasma 42PFP5532D/12 bloqué en digital TV Répondre en citant
C'est quoi la réf de ton LCD ? Il y a deux solutions:
avec Compair, ou remplacer la mémoire, mais c'est très compliqué de redémarrer ensuite.....
yonel
MessagePosté le: Lun 23 Jan - 22:06 (2012)    Sujet du message: Plasma 42PFP5532D/12 bloqué en digital TV Répondre en citant
C'est un 20PFL5522D/12
Mémoire cad EPROM?
MessagePosté le: Mar 24 Jan - 12:49 (2012)    Sujet du message: Plasma 42PFP5532D/12 bloqué en digital TV Répondre en citant
Oui mémoire = Eeprom......
yonel
MessagePosté le: Mar 24 Jan - 16:03 (2012)    Sujet du message: Plasma 42PFP5532D/12 bloqué en digital TV Répondre en citant
Merci.
Donc si j'ai bien compris je peux le jeter :-(
Pas moyen de le réutiliser juste en HDMI ? (c'est pour brancher une box et une xbox)
MessagePosté le: Aujourd’hui à 00:38 (2018)    Sujet du message: Plasma 42PFP5532D/12 bloqué en digital TV
Page 2 sur 3
