panne allumage plasma samsung
Dams666
MessagePosté le: Mer 2 Jan - 06:06 (2013)    Sujet du message: panne allumage plasma samsung Répondre en citant
marque:samsung
model:PS58B680T6W
model code:PS58B680T6WXXC
TYPE:PS58B680
SN:867334PS500464D
BONJOURS A TOUS !
VOILA JE BRANCHE LA PRISE DE COURANT, JAIT LES DEUX VEILLE ROUGE,JE LANCE LE DEMARRAGE PUIS LES RELAITS CLAQUE EN CONTINUS,DONC ALLUMAGE EXTINCTION.BREF JE LAIT OUVERT PRIS LES TENTION SUR TOUTE LES FICHE CN.ELLE SONT TOUTE BONNE SUR LA CARTE ALLIME.JAIT CONSTATER UN FUSIBLE HS SUR LA CARTE DE GAUCHE C LA PLUS GRANDE DES DEUX QUI JE PENSE ALLIMENTE LA DALLE.DONC QUAND JE DEBRANCHE L'ARRIVEE D'ALLIMENTATION DE CETTE CARTE LE PLASMA S'ALLUME,ENFIN LE RELAIT CLAQUE LES VOYANT ROUGE S'ETEIGNE,MAIS PAS  D'IMAGE PAS DE SONT.
JAIT REMPLACER CE FUSIBLE EST C PAREILLE MAIS IL NE CRAME PAS,BON JAIT PAS NON PLUS LAISSER 2 MINUTE LE TV EN MARCHE POUR PAS AGRAVER.
SI QUELEQUE PE ME DONNER LA MARCHE A SUIVRE POUR CONTROLER TEL OU TEL COMPOSANT,JAIT CE QUIL FO:TESTEUR FER A SOUDER SMD OU NORMAL!
MessagePosté le: Mer 2 Jan - 06:06 (2013)    Sujet du message: Publicité
